-   -   Comb tiller/Brinly moldboard ? (https://www.onlycubcadets.net/forum/showthread.php?t=18194)
prespres 05-27-2012 11:47 AM
I would like to hook on to a brinly plow to rip ground up and then switch to my 1A tiller. I read somewhere that the gear box needs to be removed but when I mount the hitch it hits the plate the gear box is mounted on. I don't want to have to change hitches all the time. Any suggestions?
Andy
aarolar 05-27-2012 12:53 PM
Andy
Buy another cub?
cub123 05-27-2012 01:31 PM
If another cub isn't an option, the next best thing is to make some extensions, like this....
http://emob1192.photobucket.com/albu.../MXBEN/867.jpg
http://emob1192.photobucket.com/albu.../MXBEN/567.jpg
This will let you run the plow with the gearbox on, you will also need a longer pin in the upper lift casting. You also may want a skid plate to avoid messing up the pulley when plowing...
http://www.onlycubcadets.net/forum/p...pictureid=1812
_DX3_ 05-27-2012 01:36 PM
3 Attachment(s)
xtrememotorworks.com makes an extension kit for the sleeve hitch adapter and a longer pin to compensate for the extra length
Attachment 25023
Attachment 25024
Attachment 25025
Jeff in Pa 05-27-2012 08:13 PM
I make extended sleeve hitch adapters with longer lift pins :IH Trusted Hand:
I make lots of goodies
http://img.photobucket.com/albums/v7...s/DCP_6019.jpg
CADplans 05-27-2012 08:37 PM
And they look GOOD!! :bigeyes:
prespres 05-29-2012 07:49 AM
Sounds Good
Thanks for all the help. I was wondering if there was a solution.
Andy
