Rear PTO ?
Wanting to add rear pto on a 982 rear. Which one or ones will work. Also, down the line would like to add on cat 0 lift. I don't see where that matters but thought I'd add that. Thanks for your help.
luke |
You have to have the Cat-0 lift to use the 3-point, and only the 3-point and rear PTO from another super will work. If your 982 has a cast iron rear, the rear cover plate you'll need must be from a 982 if the rest of the PTO came from a later tractor with an aluminum rear.
Confused a little
Not quite sure what I'm reading, sorry. Let me say I haven't started this project yet and I'm really going to struggle with it. I bought a 1572 with a cracked aluminum rear. I purchased a 982 cast iron rear to put in it's place. Now I've decided to put rear pto on while everything being changed over. So I want to be sure that all the parts I get will be right. Also would like to put on 3pt hitch on in the future ( probably can't afford right now). Trying to put all my ducks in a row without mistakes. Also thinking I'm going in the wrong order because having the 3pt hitch first makes more sense.
luke |
If you still have all of the internals from the aluminum rear, they will fit into the cast iron rear. The internals from the aluminum rear are stronger and have fine splined axles. Also, the axles have studs on them - makes tire removal/replacement a little easier. The cast iron internals have a bevel cut ring and pinion, while the aluminums have a straight cut, so if you decide to switch these out, you'll have to change out the pinion shaft or swap the ring gears. I swapped everything for my 982, pinion and diff, and it works great. Just my :TwoCents:
Any pictures
Hey Maddog, Did you happen to take any pictures of your project? Would help me to get a visual. Will try to do a search to see if there are other rear change outs.
luke |
If you use the 982 rear end, you'll need the cover for a pto rear end. Good news is that http://www.ihccw.com has a plate that will fit your needs. Look under the Front and Rear PTO section and look for a red plate labed "USED REAR COVER PLATE ASSEMBLY IH 135616 C2 703-0449". That is the cover you need. After you get the cover installed, you can start looking for a complete pto setup. They are hard to find and usually cost around $500 to buy one, but once you have the correct cover installed, then you don't need to get back into the rear end to install the rest of it. Everything else is external.
AJ |
AJ, I tried contacting Ruegg a few months ago and never got any response. Are they still making them for the Cubs?
Ruegg is still making them I ordered one for my 2072 about 3 weeks ago but havent got it put on yet looks to be a nice piece.
Just looked at the Ruegg web site, says only JD. , are you sure they make them for Cubs? :bigthink:
