-   -   wheel weights (https://www.onlycubcadets.net/forum/showthread.php?t=19349)
gregfromny 07-26-2012 07:52 PM
wheel weights
how many bolts do you guys use to mount your wheel weights on the rims? pics might help thanks.:Question:
darkminion_17 07-26-2012 07:59 PM
I use 2 on each wheel.When I put 2 or more sets on I use 4 per wheel
gregfromny 07-26-2012 08:06 PM
ok do you use bolts or threaded rod? and why?
darkminion_17 07-26-2012 08:22 PM
I use carriage bolts because I have a lot of them...
Jeff in Pa 07-26-2012 09:14 PM
I use 1/2" carriage bolts too but I had to purchase mine at Home Depot.
Two bolts hold these 65 lb gulson weights on just fine :beerchug:
http://img.photobucket.com/albums/v7...h_DCP_5576.jpg
click
ACecil 07-26-2012 10:36 PM
I just use 2 carriage bolts per wheel also.
Methos 07-27-2012 12:27 AM
I like carriage bolts as well makes installing them easier. I use 4 on each side.:beerchug:
Cub Cadet 123 07-27-2012 08:45 AM
I do the exact same as darkminion_17. Two hold fine, so it really is just a matter of preference.
gregfromny 07-27-2012 09:42 AM
ok i wasnt sure i have seen a lot with the 2 or 4 setup just wasnt sure if there was a reason they did that or not
