1650 not charging
I just bought this old girl and the owner said its charging but I can tell it aint. Just for the fact when you turn the lights on they are very very dim even when its running. He by passed the voltage regulator. I found the wires but is the one for the batter suppose to be hot at all time or only when its on? I need a little help with it. Its does have the 16hp kohler still
Did you look here?? ......... V/R
well i tried it and i cant get anything out of the stator...all i know is tht the guy i got it from had it rigged to charge and it didnt charge. the more u turn on the more it pulled down the battery...but i tried hooking it up like it shows on the diagrahm and it only makes the wires get hot.
for the uneducated here...what exactly is a stator and why is it needed? Do they fail often? Is there a similar part on an auto engine? On a Kohler 3xx, where is it and how big a job is it to replace it?
I'm not being a smart-a**...I really want to know! When I read the OP, I would have suspected the VR but I really don't know anything about a stator. Is it possible that jumpering around a bad VR would kill a stator or will a bad stator kill a VR? |
thanks Roland...the answer hit me after I typed it (the automobile alternator is always spinning isn't it!) what many books refer to as the "starter/alternator" on a small engine is actually 2 separate components and that big piece hanging off the side is only a starter. back to the original post...if the leads to the vr are still there, I would get the VOM out and make sure there is no voltage (can that be done with just the bare leads or do they need to be connected)? According to your diagram, if each lead coming from the stator produces 14V AC (other probe on the VOM touched to a suitable ground), can he rule out the stator and save himself some pain?
Cub Cadets have a Starter / Generator, not a Starter / Alternator.
A generator produces a DC Voltage. A alternator produces a AC Voltage. Quote:
From the previous link. there is two (2) tests to perform. One is a static test where one measures resistance on the stator coil. The second is a "performance test" where one measures the voltages while the engine is running at WOT. Voltage from the stator is around 30VAC. Voltage from the center tap of the V/R to chassis ground is 13.7VDC. |
well guys ive tried everything to fix it. took a harness off of a 1200 cub tht had a bad motor and put it on my 1650 then got a new v/r and it fired it *bummer* but i think the stator is bad cuz it wont ohm out at all running but off it ohms out.
but id like to thank you DX3 and R Bedell for the info and advice. i hope to find a stator or get it fixed and get it back out again. didnt like my 1650 at first but now i realize how much power it really has running poorly prolly have more running and charging right |
If the engine is running you can not make a ohm measurement of the stator you will damage your meter.
To check it while the engine is running you have to set your meter to AC with an AC voltage range > 35V. With the engine at WOT you will read an AC voltage around 30 volts. |
| All times are GMT -4. The time now is 02:23 AM. |
