-   -   Cub 127 Hydro (https://www.onlycubcadets.net/forum/showthread.php?t=21406)
deeseoid 12-01-2012 10:35 AM
Cub 127 Hydro
Newbie seeking info on use of attachments
Should I be able to use rear mount attachments(3pt. hitch) with the front plow blade hanger in place.
I have interference with the rear deck hanger pins and I don't know if that is because my plow blade hanger is bent or it is not designed to be used together.
Appreciate any response.
Muzzy 12-01-2012 10:59 AM
I had that problem on my 147. All I did was spread the back of the plow frame a little and it cleared.
Methos 12-01-2012 12:12 PM
:Welcome2:
I think if you lower one the other one lowers with it.:bigthink:
Cubcrazy 12-01-2012 01:45 PM
:Welcome2:
deeseoid 12-02-2012 08:43 PM
re: Cub 127
Thanks for the input folks. I straightened the plow hanger a little to give the same spread at the back as the front. Should solve the problem.
