-   -   1862 (https://www.onlycubcadets.net/forum/showthread.php?t=21636)
knucklebuster283 12-15-2012 02:55 PM
1862
I am new to site.
I started this for a friend at work. He blew a rod in the M-18. We could not find another M-18 so are going with a CH-18. I have gotten as far as getting the engine setting where it needs to be and bolted. The PTO lined up and hooked up. Now I need to find out what models this engine was used on, as the wiring is different. The M-18 only had three wires to the tractor with a three slot connecter, the CH-18 has six, with a five slot connecter. the guy I got the engine didn't know what model cub it came off but 100% sure it's off a Cub.
R Bedell 12-15-2012 03:13 PM
The Kohler CH-18 was used in Cub models 1863 & 1864
Sam Mac 12-15-2012 05:05 PM
And others. That engine looks like it's out of a 2185. Go to the Kohler web site and download the CH 18 service manual it has the wiring diagram in it.
knucklebuster283 12-15-2012 05:06 PM
Thanks Roland big help. Same to you Sam. Should have known you'd be in here also. Kevin from MTF
Sam Mac 12-15-2012 05:27 PM
Kevin
Yep, I spend way too much time here. One of these days I need to get a life. LOL.
Should be an easy swap for you. I did the same thing with an 1882 and a new CH22. Biggest PITA issues are the drive shaft, muffler and heat shields. Holler if you need help.
Mac
Cubcrazy 12-15-2012 08:01 PM
:Welcome2:
Mike McKown 12-16-2012 02:26 PM
Compare your PTO pulley size on the new engine vs the old.
knucklebuster283 12-19-2012 10:25 PM
The pto is off the m18. Bolted right up to the ch18. As Sam said the pita is the driveshaft and exhaust. the ch18 sits about 2"s forward more than the m18 did. The 1862 shaft is now that much short, also making less room up front for the muffler. May just stack it as the owner has cracked the plastic sidecovers right where they snap into the grill support, so they flop. Dave the owner only paid 400.00 for it. I've told him a number of times to take care of it. That he was sitting on a $1200 to $1500 tractor. Some people just don't care. As long as he's willing to pay I'll fix it. I ain't doing this one as a freebie.
knucklebuster283 12-19-2012 11:52 PM
3 Attachment(s)
Some pics with the CH18 in
Sam Mac 12-20-2012 07:07 AM
Look for a drive shaft out of a 1863 or 1864, same for the muffler. I put a pipe nipple a 90 and a hose on the CH’s when I do a swap for the oil drain.
