-   -   Hydro seals (https://www.onlycubcadets.net/forum/showthread.php?t=21880)
JK777 12-30-2012 02:10 AM
Hydro seals
I’m looking for part # and a source for a couple of seals. The ones I need are #5 and they are for a cc149.
cubby102 12-30-2012 03:56 AM
The part number is on the cub cadet parts lookup page. And pretty much any cub dealer can get them
Sam Mac 12-30-2012 06:39 AM
Cub part # IH-383534-R91
Make sure you read the manual on how to change those. You need to open the pump up and remove the trunnion shafts in order to replace the one on the control lever side. At that point you will need the case gasket and you should change the other two seals.
Oak 12-30-2012 08:41 AM
Hydro trunion seal Ser# 592014 & below (IH# 383534-R91) is a NAPA #6720
Ser# 592015 & above (Sunstrand #9008000-6701) is a NAPA #6763
Input seal (IH 394847-R1) is a NAPA #6204 or a National #471466
JK777 12-30-2012 01:08 PM
Thanks for the quick responses. Looks like the pump is coming back out:angry:
I was hoping that they could be changed from the outside but looks like if I’m digging in that deep I might as well change all the seals.
Methos 12-30-2012 02:58 PM
Great plan!:beerchug:
Sam Mac 12-30-2012 04:22 PM
I strongly suggest that you down load the service manual http://www.onlycubcadets.net/forum/s...ad.php?t=13226
and read the disassembly and repair procedures for the pump. One big area of caution is the removal of the roll pins that hold the trunnion shafts in the swash plate. It is not hard to do but if you screw it up you are in trouble. Make sure you keep everything CLEAN. Holler if you have questions. :beerchug:
JK777 12-31-2012 02:42 PM
How did you cross-reference to a Napa part number?
