-   -   Hitch for a 106 (https://www.onlycubcadets.net/forum/showthread.php?t=22265)
2cubcadets 01-22-2013 10:23 PM
Hitch for a 106
I was planning on building a box blade
But have no hitch on the 106. I am new to
this so was hoping I could get some advice
I have seen the hitch that is spring assisted
That uses deck lever to operate. I assume
Blade will weigh about 150lbs will this hitch
Work ?
cub123 01-22-2013 11:03 PM
The hitch will work fine, but I think 150 lbs is a little heavy for a narrow frame, and your arm is going to be sore with a manual lift, here's my 106 with hydo lift and IH box blade, I don't think it weighs more than 70 lbs, a guy on here made some heavier repos copying the one i have that I'm guessing were about 100 lbs and everyone says they are about right. You might find this helpful... http://www.onlycubcadets.net/forum/s...ad.php?t=12035
http://i1192.photobucket.com/albums/...1358130734.jpg.
Matt G. 01-22-2013 11:20 PM
The tiller weighs like 220 lbs. or something like that and is not that hard to lift with a spring assist.
4SPEED 01-22-2013 11:46 PM
Matt, I bet it's not much over 150. I picked my #1 up to load it in my truck. its awkward as all get out. and is one big finger pincher for sure.
on my 582 with spring assist it picks up easyer then the 10'' plow
cub123 01-23-2013 12:09 AM
I've never lifted anything but the brinly with my spring assist, i guess the extra leverage makes it feel heavy. As long as it's kept close to the tractor it should be fine then:beerchug:
macman81 01-23-2013 09:16 AM
my homemade box blade only weighs about 50 lb and it digs into hard packed gravel pretty good when i add one cement block to it. i think its more the angle and design than the weight that makes them work. i can adjust the angle of min depending how much bite i want. looks kinda silly but works great.
2cubcadets 01-23-2013 11:01 AM
Hitch
Thanks everyone for your help
martyrant 01-23-2013 12:09 PM
Macman, do you have any closer pictures of the box blade? I'm going to either need to find or build one this spring; I've seen the cheap brinly 38" one at casa depot for $190, but I question the build quality of a lot of newer stuff (if anyone has that and it's decent, let me know). I saw that reproduction thread for the #40 back blade and that is nice, but I don't think I have nearly the resources to pull something that nice off.
drglinski 01-23-2013 02:09 PM
X2 ----agreed. Spring assist makes lifting a tiller MUCH easier. (plus it's easier to pop wheelies with a tiller, don't ask me how I know that.)
Matt G. 01-23-2013 03:56 PM
The #1 tiller manual says 200 lbs shipping weight (whatever that means) with 1 extension. The other extension is probably close to 20 lbs, so assuming the gearbox is included in the 'shipping weight', it's still more than 150...
