checking an hour meter
2 Attachment(s)
Got this hour meter off the 125 and nor sure if it works or not because I haven't used the tractor yet.
I've got it out and was wondering if there is anyway to check it to see if it works? Being there is a positive and neg. could I just hook it to a charger and see if it moves? In theory that's how they work when the power is put to them, right? Thanks |
I'm pretty good at sittin':biggrin2: |
Use a battery, not sure how a half wave rectifier in the charger will affect it.
they don't draw much, so no problem there. hook it up, note time, come back in the morning and compare. |
I got one of those for my 128 but I am going to have to fab the rear bracket for it. You happen to have a pic of that? :bigthink:
Well I had it on the charger, (didn't check site since last night) this morning for three hours and nothing moved. Sooo, you think it's shot, or give the battery thing a try?
DWayne, the PO put mine in the hole then drilled holes around it and attached with screws and washers on the side. Pretty tacky! |
You should be able to put it to your ear and you will hear it tick.
| All times are GMT -4. The time now is 02:13 PM. |
