-   -   Gear box lube (https://www.onlycubcadets.net/forum/showthread.php?t=22773)
peterjt408 02-20-2013 09:45 AM
Gear box lube
What lube is specified in a snowthrower gear box?
cubby102 02-20-2013 09:53 AM
I put in wheel bearing grease (high temp abs rated) seems to be working fine
peterjt408 02-20-2013 10:02 AM
Thanks, cubby.
ol'George 02-20-2013 12:03 PM
If the seals are good you can use 85W90 gear lube ( car truck rear end lube)
If they leak, you can use light chassis grease.
Some ppl mix the 2 together, all with good results.
peterjt408 02-20-2013 12:07 PM
Thx ol'George.
squatch 02-28-2013 06:36 AM
MY 450 snowblower specs some kind of plasticlube if I remember correctly. Has anyone ever tried to use CV joint grease. That stuff is pretty sweet. not real heavy but sticks to everything. I have plenty of that with moly graph in it.
R Bedell 02-28-2013 08:45 AM
This chart is based on the IH Operator's Manuals....
http://i176.photobucket.com/albums/w...psd291b38e.jpg
restore49 02-28-2013 09:34 AM
What about a Synthetic 90W - good at lower temp.
R Bedell 02-28-2013 09:52 AM
You can put in whatever you want. It is your tractor. The chart is what is recommended. It's your choice to follow it or not.
rmunro 02-28-2013 01:43 PM
CV joint grease
I was wondering the same thing.
