cub cadet 129 charging problems
I have a cub cadet 129 with the kohler k301. I recently rebuild the starter/generator due to what i thought was the problem.... while its running the voltage across the negative and positive of the battery jumps from 1 volt to 19 volts, as well as at the regulator and S/G. anyone had this problem before and know how to fix?:HeadScrath:
Somewhere there is a short occurring. I would check by the vr, the wires get pretty close to the frame there and may have worn through the insulation on the wires.
I'd be looking to see if your meter is working correctly or on the correct scale.
I noticed some frayed wires along the lines to the v/r and s/g i thought i got em all covered... might have to re wire it then. any suggestions on what it could be if its still a problem? could the v/r be bad?
Also the meter is on the right setting. when the tractor isn't running my battery reads 12.37 volts and stays steady doesn't jump. Also ohms everything out just fine.
That don't compute unless your battery is totally junk with an internal intermittent connection, or you have loose connections at the battery. A battery @ 1 Volt is junk and would not start anything. Check your battery terminals/wire ends. |
Imporper wording :bash2: sorry. flucuates from 1 to 19 volts and never stays steady.
If the battery is starting the tractor and it sounds like it is, I'm with Roland you have a connection problem.
Your test leads on the BATTERY POSTS not the wire ends/terminals should be a steady voltage reading. A battery cannot fluctuate that wide of a range, and be good/usable. @ rest maybe 12V. min. and running full throttle/charging 14V.( ball park) |
I currently have wire harness out couldnt find much places with wear on them. Remade a hardness for it last night and will reinstall it tonight.
| All times are GMT -4. The time now is 09:14 AM. |
