| rosshurlow1 |
03-10-2013 12:20 AM |
Best way to rebuild a k301
I have a 123 hydro with the 301 12hp and two years ago I restored and rebuilt the motor but it never ran right. I replaced the generator, points, condenser, piston, rod and rings, lapped the valves, but before I put it back together I was young and stupid and I did not understand compression release and increased my exhaust valve gap to stop it. I restored the valve gap but it still did not even start. I have decided to rip the motor out and do it completely right. I checked the bore and it measured 3.485 all the way around with it honed. And when I took the motor apart the first time I lost one of those adjustable plates for the governor and made one which made it mow with a unstable idle. Currently I ordered a new governor assembly, ignition coil, and a carburetor rebuild kit. I want to purchase a complete rebuild kit with gaskets and all. I have mixed feelings of replacing the rod, piston, and rings but they didn't even have 20 hours on them,but when I tried to start it in storage today when it cranked the dipstick shot up 2 inches with each rpm, and when it did run it would pop up and down so I had a spring from it to the generator keeping it down. Would I want to replace the governor gear while in there? I had a couple tablespoons of oil leaking from the valve cover breather hole as well. Any help would be much appreciated. Thanks
