-   -   Brinly Plow (https://www.onlycubcadets.net/forum/showthread.php?t=23260)
kycub 03-14-2013 08:33 PM
Brinly Plow
I recently found a Brinly plow for my Cub 100. I've noticed that the plow needs to sit closer in line with the inside of my right rear tire. Unlike most I've seen, the plow only has one hole for attachment to the sleeve hitch. What can I do to remedy this?:bigthink:
aagitch 03-14-2013 09:05 PM
You could get this.
http://www.xtrememotorworks.com/Part...ow%20Parts.htm
Merk 03-15-2013 07:44 AM
Does your plow look loke this one?
http://i152.photobucket.com/albums/s...nfo/plow04.jpg
You can't use extrememotor works hitch because your hitch is welded on from the factory.
I added an extra material to the clevis part of the hitch.
http://i152.photobucket.com/albums/s...lowhitch02.jpg
This plow is used on my 100.
