-   -   Hy-Tran in Truck transmissions? (https://www.onlycubcadets.net/forum/showthread.php?t=23404)
bocephus1991 03-20-2013 06:08 PM
Has anyone ever heard of or know anyone who has used Hy-tran in their manual
trannys or auto trannys for their pick-ups or cars? Any reason it wouldn't work? thanks,Brian:American Flag 1:
TheIHMan 03-20-2013 06:15 PM
I don't see why it wouldn't work. It's the best stuff out there for Cub Cadets and tractors.
ol'George 03-20-2013 06:30 PM
It would be my opinion to go with the factory recommendation in an automatic transmission, as some have specific needs, that possibly hytran would not best be suited.
on the reverse, ATF is specified as an alternative by Sundstrand.
The fact that hytran absorbs moisture might not be a good thing in an automatic where an emulsion of water/oil
would cause a problem, but I'm no oil expert.
At the cost of hytran, I would think mercon or Dextron would be economically a better choice.
Replacing a automatic is a costly experiment compared to a used hydro for maybe $100.
CADplans 03-20-2013 07:35 PM
My S-10 5 speed manual requires synthetic.
Many manual transmissions require sulfur in the oil.
Hytran meets neither requirement.
Automatics are so expensive, I would not second guess the designer.
:bigthink:
Muzzy 03-20-2013 07:39 PM
I think ol' George hit it on the head. Hytran isn't for everything.
Mr.Goffena 03-21-2013 12:53 AM
I use hytran in my font and rear diff on my pickup. I haven't run it very long like this, but a guy I work with has been running it in his ford for 250,000 miles with no problem. Its really noticeable in the wintertime. Hytran has more friction modifiers than gear oil does Plus CaseIH use it in some of there front diffs and planetaries so I don't see why a pickup could not use it. I would not use it in any transfer case that uses ATF because in really cold weather the oil could be to thick and ruin the pump, same goes for an auto tranny.
gcbailey 03-21-2013 08:23 AM
so I shouldn't be using it as a teeth whitener? :bigthink: :biggrin2:
Muzzy 03-21-2013 09:32 AM
I think it'll be OK for that.
Methos 03-21-2013 11:04 AM
Nope but it's great for having that tractor smell on you for date night with the wife.:beer2:
ACecil 03-21-2013 11:29 AM
Yep, nothing like the smell of Hy-Tran! :biggrin2:
