Which hydraulic components?
A future project I have planned will require hydraulics. Is the cylinder, lines, controls and power unit all I need, or am I missing something?
YUP.....that's it until we have more information.
:ThumbsUp: |
I was thinking of making something too. Not sure if it will need hydraulics though. What do you think?:biggrin2.gif:
I'm building a loader. I want to lift 500lbs, but want to keep the frame light. I know I need a long stroke cylinder for the raise, and a small one to dump the bucket. I'm looking for a power unit that will control both, I know I'll need a small reservoir tank and lines (obviously). What I'm wondering is do I need a pump and power unit? Should just be the power unit right?
Please define your version of "pump" and "power unit".
The pump is the power unit. Unless you mean the control valves.
One more thing you can't forget Stitch....Hydraulic Fluid! :biggrin2.gif: |
If you're planning on being able to lift 500 lbs, you will not be able to build it 'light'. The OEM loaders built by Kwik-Way, Johnson, Danco, etc had a load limit of 250-300 lbs. or so. It would not be wise to try to lift more than that with a small tractor such as a Cub Cadet, IMHO. You will need a massive amount of counterweight to be able to lift that. You need to have a decent factor of safety built into the structure to avoid breaking it under abuse.
A 100 drained of all fluids probably weighs not much more than 500 lbs... |
500 lbs was rough. I have a lot of thinking/planning to do. What I am planning is to build the frame from 2 inch square steel tube, with 1/4 inch walls. Assuming I try for a 250 lb capacity, would this work? I'm more of a novice welder so far, but everything I've done has worked out well.
Stitch, you don't need 1/4" walled box. 3/16".....maybe even 1/8" will work because it's boxed. But the welds need full penetration, with no pinholes.
You'd be surprised how strong square tubing is when welded right. The lighter the loader, the less counter weight needed. Say you're lifting 400#......you need to add the weight of the bucket and arms when figuring counter weight. Bobcats don't have 1/4" thick tube.... I was just told my 124 weighs 625#. The trans, and wheel gotta equal half, plus the driver....400#-500#. You probably need another 100# per wheel, and load the tires w/rimguard. But that'll only even it front to rear. It could still tip side to side....I've seen them with dualies....that'd be optimum setup. |
Here is a site that has plans for a loader:
http://www.p.f.engineering.50megs.com/index.html Not sure how they charge for the plans to build a loader. They do recomend what hydraulic pump, cylinder and control valve that work with their loader plans. |
| All times are GMT -4. The time now is 07:13 PM. |
