-   -   317 deck parts or repair (https://www.onlycubcadets.net/forum/showthread.php?t=23814)
Cannon51 04-10-2013 06:33 AM
4 Attachment(s)
The gage wheel bracket on my 1863's 317190 deck has been damaged and repaired, but is hanging out a few inches past the deck. This only invites more damage. I looked for a parts drawing but all I found showed a different type wheel on the chute side. The pin is bent and twisted and the arm is also twisted. I would like to repair these parts if possible. Recommendations?
Cannon
Sam Mac 04-10-2013 07:05 AM
The Cub Parts site shows your deck.
Cannon51 04-10-2013 07:15 AM
I saw that one but was not able to make the chute side parts look like mine. Would #36 from the left side work on the right?
Cannon
Sam Mac 04-10-2013 07:40 AM
Cannon
It calls for 2 of item number 36 so I'd say yes it will work on the right side
# 50 Spindle Assy, RH Front You may be able to straighten yours
Part Number:603-0110
# 36 Castor Assy, Front To me this looks more like an arm but they call it a caster
Part Number:703-2094
Mike McKown 04-10-2013 08:43 AM
I have a 48" deck that was bent up a little worse than yours. I got everthing straightened back where it belonged and re-welded some crappy welding in about an hours time.
I used a acetylene torch, stick welder, vice, pipe wrench. It's not hard to do if you have those tools. If you don't, I'd hate to have to buy that stuff new.
Sam Mac 04-10-2013 09:01 AM
703-2094 looks like it is about $44.00
Methos 04-10-2013 10:20 AM
Don't forget about our awesome site sponsors for your parts needs.:beerchug:
Cannon51 04-11-2013 05:28 AM
I got the parts reasonably straight using a pipe wrench, vise and 3 foot bar. Two welds broke on the arm when I untwisted it but I dobbed some more on. The shaft had a twist that I reduced by rotating the end with a pipe wrench then filing the marks out. Got some more bushings for the arm. I hope to get finished today and get the deck on.
Cannon
Cannon51 04-11-2013 09:15 AM
2 Attachment(s)
I've got it back together. I have at least reduced the "sore thumb" look of the arm and wheel. I intended to take the deck apart, repair and paint it this winter but maybe next year.
Cannon
Cubcrazy 04-11-2013 09:26 AM
Thanks for the update Cannon!
Looks alot better!
