1572 front wheel removal
Hi. Is there a trick in getting a front wheel off of a 1572 SGT? I've removed the single bolt/washer but the wheel seems to be stuck pretty tight. Appreciate any advice.
There shouldn't be anything else holding it on. It's probably just stuck.
The trick is a block of wood on the backside of the rim and a sledge hammer. A couple of hits should knock it off.
AJ |
1572 - front wheel stuck
| All times are GMT -4. The time now is 04:17 AM. |
