-   -   1860 electric clutch problems (https://www.onlycubcadets.net/forum/showthread.php?t=23928)
leonmathis 04-15-2013 07:44 AM
After taking 4 years to rebuild my cub I was ready to mow Saturday and when I engage the clutch the mower starts but when I release the switch to it on position the mower stops. Any ideas? Thanks Leon
R Bedell 04-15-2013 08:19 AM
It could be: (A) A seat switch, (B) the reverse switch, or (C) reverse relay.
leonmathis 04-15-2013 11:27 AM
Will this let it start but not continue to run and what is the reverse relay do?
R Bedell 04-15-2013 11:33 AM
The reverse relay is designed to kill power to the Elec PTO when the hydro lever is placed in the reverse position.
Mike McKown 04-15-2013 06:18 PM
Is that relay NC or NO?
R Bedell 04-15-2013 07:28 PM
The Reverse Relay on this Tractor is Normally Open (NO).
Mike McKown 04-15-2013 08:30 PM
Thanks....
leonmathis 04-17-2013 10:46 AM
Got a hold of a wiring diagram and found it was a bad relay. Thanks
Mike McKown 04-17-2013 11:11 AM
Trying to mow with a dead battery will also cause this problem. Had it happen to me yesterday as a matter of fact!
Methos 04-18-2013 11:56 AM
I moved this to the GT section.:beerchug:
