Cub Cadet 71 Tips and Tricks to Make it Run
My new to me 71 Cub Cadet has been sitting in storage for 5 months. It ran before it was parked. What do I need to do to before I try and start it up? I am new to Cub Cadets and garden tractors.
Thanks, Kyle |
Try turning the key, 5 months isn't that long.
He's talking about starting it up, not regular maintenance. Unless it's wicked dark its probably fine to run anyway.
Yeah, I would put a hot battery in it and fire it up... Find out what you've got, then take care of your maintenance.
Just my .02 !!! :beerchug: |
If the oil level is ok, start it, let it warm up,(mix all that dirty oil & sediment off the bottom of the oil pan ) shut it off then drain the dirty oil out. At the same time your burning any old gas that may have been left in the tank & carb. Also before you start the engine, you may want to add a little gumout or seafoam to the gas tank to help clean the fuel system while your running it too! Sorry, I just thought of this, Pull the spark plug and look at it before you do anything. It'll tell you alot about the engine condition before you even try to crank it over. Good Luck!
I always change the oil first, and just check it for debris. I started a K-181 that was on a WH without first changing the oil, and it seized. Found out that there were lots of shavings from the cylinder wall in the oil, and I'm guessing they had something to do with it. :bigthink:
| All times are GMT -4. The time now is 06:07 PM. |
