-   -   126 W/ implements (https://www.onlycubcadets.net/forum/showthread.php?t=24366)
JONDAVHAR 05-03-2013 10:13 AM
126 W/ implements
Any idea what this setup is worth? Owner is asking $500....not pictured is a 42" deck, description says runs good but needs generator....Thoughts?
Thanks!
http://images.craigslist.org/3Lc3Ie3...15f4fd1431.jpg
Methos 05-03-2013 10:22 AM
Thanks!
That is a fair price in my neck of the woods. Not sure why they hacked up the plow for.:bash2: Looking back at it looks like the sleeve hitch adapter, lifting straps and lift pin are still attached to the plow.
ToddW 05-03-2013 10:39 AM
seems like more than fair price for around here to, with a lift and those attachments
JONDAVHAR 05-03-2013 11:00 AM
Here is another view....I may have to go look into this.
http://images.craigslist.org/3E83M93...ecc8d3161b.jpg
sawdustdad 05-03-2013 11:30 AM
Looks like it's been re-powered. Check what they put in it. Looks like a good price, though.
ACecil 05-03-2013 11:30 AM
That's not a bad deal at all! Hope you get it!
Yosemite Sam 05-03-2013 11:45 AM
I would look it over really well, something doesn't look right with that front blade and it's hard to tell from the picture what they have done there on the back end.
I'm not saying that all PO mods are a bad thing... Just make sure they work as they should, or that they can be reversed without a ton of additional cost.
Even here in "the land of no Cub Cadets" $500.00 is pretty-much top dollar for what is there.
Good Luck
red56turbo 05-03-2013 01:16 PM
Looks like they added a bracket of some sorts to the back to add the ball hitch. Hard to tell from the pic, but I don't see the rear lift assembly. The front blade is either hacked up or not correct for a cub, once again, hard to tell from the pics. Rear plow missing the coulter. The engine's black, so probably a replacement at some point. It is a 126, third lowest production cub numbers wise, so that's worth something to a collector.......... Good luck and keep us posted.
