-   -   Using a 44C deck on a 1450? (https://www.onlycubcadets.net/forum/showthread.php?t=24697)
gdheck 05-15-2013 03:51 PM
I have a 1975 1450 and a 44C deck off of a 1987 1211. Can I just change the top center pulley to use this deck on my 1450? Anyone put a slightly smaller pulley on the deck to make the blades run faster, but not dangerous fast? Anyone got a part number for the correct pulley and belt for this setup?
Thanks,
Geoffrey
R Bedell 05-15-2013 04:08 PM
Change the center pulley to the same one as seen on a 44A. I assume you have the correct Mule Drive and if so.........off to the races.:biggrin2:
sawdustdad 05-15-2013 09:04 PM
Just did exactly this. 44C on a 1450. Bought a new double pulley from ccspecialties. easy-peasy. Hardest part is balancing that dang deck so you can get to both sides of it at the same time! A pair of sawhorses helps.
