-   -   New member, from Rhode Island (https://www.onlycubcadets.net/forum/showthread.php?t=25546)
Wheelie 06-19-2013 12:10 PM
I am anew member of the club ,and wish to participate. I have recently purchased a Cub Cadet 105 hydrostatic trans . I found the wear button to be missing and the thrust button has worn out the the shaft clutch. I am wondering if I could fill in the old hole and then drill a new one ?
Any advice would be helpful as it is my first problem. The Kohler engine seems to run good and I also got rototiller and snow thrower plus the grass cutting deck with it. I find that 105 info is sketchy any help would be nice.
Thanks
Wheelie
Cubcrazy 06-19-2013 04:50 PM
Welcome to OCC! We like pics here!
R Bedell 06-19-2013 05:26 PM
Hmmm..........just what are you looking for....????
ACecil 06-19-2013 05:32 PM
Welcome to OCC! Good luck with your 105!
jeepchicken5000 06-19-2013 05:42 PM
welcome to OCC neighbor since I live in CT :beerchug:. pics would be great to
mikejr555 06-19-2013 07:50 PM
I am in RI and also a brand new member here. I have found a ton of great info here so far and I'm sure you will as well.
105_Tom 06-19-2013 09:09 PM
The 105 is a part of a great series of Cub Cadets that have awesome styling lines and a pretty good following on here. The wear button can be replaced or drilled out as needed, depending on the level of wear to the thrust arm. I had one on a 72 that was soo worn down that I replaced it rather than try to weld it up. Post some pics of the tractor and the thrust arm. You also want to make sure that it has not ate into the PTO thrust button fingers.
:Welcome2:
:cub 4:
zippy1 06-19-2013 09:41 PM
Welcome to OCC.
Pictures are always a plus.
drifter 06-19-2013 09:46 PM
What town?
jeepchicken5000 06-20-2013 06:17 AM
drifter I live in Windham county in Scotland where are you
