Cub Cadet 72 creeper gear install
hey guys, decided to put the creeper gear in my 72, i got the S/G off, the battery, and engine out, the frame was really dirty in there, i started to clean it out , heres some pics of progress:beerchug:
engine is out
Keep up the good work, Nick.
Your 50% there! Lookin good. Hardest part is the pins. The ones in my 124 still won't give up their rusty grip
exactly, i cant get them out:bash2:
finally got them out with a 3lb hammer and punches and a 1in thick solid piece of brass, also used kroil penentrating spray oil :beerchug: also got the coupler off the driveshaft and clutch out of tractor :beerchug: the spirol pins were a PITA
the holes in the clutch and coupler and input shaft are very good and tight :beer2: no wonder we had so much trouble getting them out, i also had to flip the tractor over
the clutch, where do i cut the shaft right on the score line?:bigthink:
broken pin that was in the input shaft/coupler
Yep ya cut it right on the score line be hui ind the hole.
| All times are GMT -4. The time now is 08:15 PM. |
