-   -   Sloppy throttle shaft on my 123. (https://www.onlycubcadets.net/forum/showthread.php?t=27118)
Muzzy 09-06-2013 07:46 AM
Where can I get the repair washers?
Thanks.
James K 09-06-2013 10:50 AM
I got mine at ACE Hardware. James
jonjunk 09-06-2013 10:56 AM
Here's detailed info with the part number and size
http://www.onlycubcadets.net/forum/s...ad.php?t=10329
the way they have it labeled in store for the thrust washer has the first two dimensions reversed obviously you cant have a 7/16 inside diameter and a 1/4 inch outside diameter.
I could not find the screws for the throttle plate at ace though the bronze thrust washers I found quickly
