Crank shafts
Can someone please refresh my memory to the differences between the k series engine cranks and the magnum engine crank.
the mag cranks have a 3/8 fine thread bolt holding the flywheel on. They are also nodular iron vs cast
Thanks Don. The nodular iron makes them much stronger correct.
your AQS was probably short blocked at some point in time.
they are a much better crank |
I do know that on the magnum cranks the pto end is larger than the k series
no, you could get them in 1, 1.5 and tapered for generator use
if you have the 3/8 bolt its either a replacement engine or was short blocked
new cranks have had the bolt and a bushing for in the aluminum cup for about 15 - 20 yrs. now
| All times are GMT -4. The time now is 01:55 PM. |
