Manual PTO adjustment tools?
I realized the other day when I rebuilt my 128 PTO, that I had forgotten it took a special cut tool to adjust it correctly to OEM specs. It just so happened that I found the one I got years ago to adjust WF PTO's. I am just curious where any of you out there, get your adjustment tools for WF and NF PTO's? I am going to need one for a NF in the near future. If anyone had access to a water jet or some other similar piece of equipment, I have mine that you could use as a template.
http://i210.photobucket.com/albums/b...ps0355ec3d.jpg |
the one you have pictured is for a NF.
Uh oh!
This is not good news, LOL. Someone lied to me years ago. Well I guess the PTO on the 128 will coming back off, altho it seemed to adjust pretty dang good. Tho I am not close to see if it will actually release using the handle. grrrrrrrrrrrrrrrrrr I've probably ruined the springs! Once again, thanks for your knowledge and help. |
Boy, you got me thinking now..... I'm going to need that tool soon too, and I also had forgotten about it... We used to have one.... Hmmmmmm. I'm gonna have to go digging.
My pto rebuild kit came with one. I actually got one with more than just the clutch disk, it came with the bolts, jam nuts, and springs. I would like to see a kit available that comes with bearing and locking collar and all the set screws too. i know I would buy one just to have around
http://i210.photobucket.com/albums/b...ps6588c2bc.jpg |
I'm wondering how much of a difference there is with adjustment between the two different tools. I'll have to take a pic of my PTO with the tool installed. As a matter of fact I'll go out and get one. :)
My first 125 come with a WF PTO. It been working fine for years. See if you have the 6 bumps (WF) or smooth (NF) PTO pulley. :beerchug: |
Some pics of the tool and PTO. All the ends touch precisely from the outer PTO edge to the center of the flat springs.
http://i210.photobucket.com/albums/b...ps123c36c1.jpg http://i210.photobucket.com/albums/b...ps03238d1c.jpg The three fingers are slightly above plane. http://i210.photobucket.com/albums/b...psfb218581.jpg http://i210.photobucket.com/albums/b...ps8fc331a9.jpg |
Using the wrong gauge results in too tight a spring setting, the correct one is 3/32 less in height.
| All times are GMT -4. The time now is 11:13 AM. |
