-   -   Cub 1440 snow plow (https://www.onlycubcadets.net/forum/showthread.php?t=28663)
mulerrich 11-28-2013 09:23 PM
Cub 1440 snow plow
I have recently inherited a Cub 1440, and am looking for a snow plow. I have seen many advertised describing the plow as for a "narrow frame" or "wide frame". Could anyone tell me if any of these will work on my 1440? Thanks.
Sam Mac 11-28-2013 09:26 PM
The 1440 is a wide frame. Great tractor by the way. :beerchug:
mulerrich 11-29-2013 03:00 AM
I am very impressed by the tractor, thank you. Does that mean that a wide frame plow should fit on my tractor, or is there more specific info that i should need to know to be sure it will fit other than just "wide frame"? Thanks.
J-Mech 11-29-2013 03:08 AM
Yes, the wide frame plow will fit. Nope, not really much else you need to know.
Cubcrazy 11-29-2013 07:22 AM
A wide frame plow will fit but the lift bracket is different and you will need the correct lift rod bracket.
Sam Mac 11-29-2013 10:46 AM
3 Attachment(s)
These drawings are from the Cub parts web site. This is the 54" blade.
mulerrich 11-29-2013 12:04 PM
Ok, could you identify the lift rod bracket that i will need on Sams diagram. Thanks. Also i have found a wide frame plow with hydraulic angle adjustment for $300 obo. Would this be adaptable to my tractor and is that a good price. Thanks for all the help.
J-Mech 11-29-2013 01:15 PM
That is a good price, but no the hydraulic angle would be useless on your machine. It doesn't have any hydraulic's on it at all. The blade would fit though. #12 and #4 should be specific to your tractor.
mulerrich 11-29-2013 04:34 PM
Thanks very much! I have two other to look at, not sure if they have the lift rod bracket, but looks like i should be able to find those parts.
mulerrich 12-02-2013 10:32 PM
3 Attachment(s)
Well i picked up the snow plow with the hydraulic cylinder for $175, and sold the cylinder to a friend for $20, so i am into this plow for $155. I have ordered the lift arm bracket from the local dealer and it should be in next week. I was wondering if anyone has tried to replace the hydraulic cylinder with a linear actuator? Any thoughts on whether this might work? would the force from the plow overwhelm the actuator? Would appreciate any thoughts. Thanks again everyone.
