-   -   NF Blade Sub Frame Problem (https://www.onlycubcadets.net/forum/showthread.php?t=29116)
mikejr555 12-25-2013 12:52 AM
Hi everyone,
I am having an issue attaching my plow subframe to my model 70. I have it correctly positioned outside the footrest brackets at the rear but when I try to lift the front it hits the axle long before it is high enough for the bolt holes to line up. I have been searching the forums and have seen numerous photos and my subframe is definitely the correct one and doesn't appear bent or twisted enough to cause a problem. Anyone else that has had or is aware of this problem that could weigh in would be great. Or anyone with a picture of the clearance between the front axle and the subframe would be appreciated. Is it supposed to touch? I can try to post a picture or two of the problem but in the meantime any help would be nice. Thanks.
Muzzy 12-25-2013 07:40 AM
I've seen that before. There are brackets that bolt to the subframe to lower it.
darkminion_17 12-25-2013 11:51 AM
Or leave the mower deck front mount mule drive on.
cub123 12-25-2013 12:46 PM
Like muzzy said, it sounds like you are missing part # 19.
http://images.partstree.com/?l=cub_c...0001&nd=0&z=30
mikejr555 12-25-2013 02:36 PM
I am definitely missing part 19. It would solve the problem for sure. I guess I will track them down or make some. Thanks guys.
Jeff in Pa 12-25-2013 03:41 PM
I can make them if you run into problems. I will need dimensions though. :beerchug:
Jeff
mmzullo 12-25-2013 08:38 PM
Like Lewis said get a front mule drive and use that. Much stronger then the lift arms.
mikejr555 12-25-2013 09:29 PM
I do have a mule drive that I haven't used since I don't mow with this tractor. Anyone of have a pic of the mule drive used in this application? Thanks to everyone for your help so far.
Cub Cadet 123 12-25-2013 09:35 PM
I have a subframe with that has been welded and cut to fit the mule drive to adapt a snow plow onto a NF 126. Is this what you are talking about or are you talking about attaching the subframe to the muledrive using bolts? Let me know if you need pics of what I have and I will set you up with them. I didn't do it, it was on my 126 when I received it.
mikejr555 12-25-2013 09:49 PM
I'd be interested in seeing that mod if it's not too much trouble. Thanks.
