Snow thrower belt tension
On the qa36a, does it make sense to tighten the 4 carriage bolts down tight after you've got the belt tensioned tight, that way it prevents it from loosening up at all??
snow thrower belt tension
I have the same question,but for a qa36. Looking forward to the answer.
I always have
the qa 36a .You do not have to loosen the bolts.
On a qa 42 you do not have to loosen the bolts. Read up on the manual. |
There r actually bushings around each bolt, this is suppose to make it so tension can be set on the belt and and u cannot immobilize the plate. Just looked like my plate was moving during operation. But hey, it's in the manual
I have been using mine for the last 4 yrs without any big problems, besides loosing a belt occasionally. But this yr, it just would work without throwing belts. A few yrs ago, I drilled a hole next to the tensioner handle, put a .25" bolt in, so it can't loosen up. I put a new shiv on, .5x3". It works great now
1/15/14 wheelie. I have a cc105 with a qa36 and need a new belt do you know the number
Of the belt? Regards Wheelie |
Qa36 Beltran
From wheelie, thanks for your response to my question for a qa36 belt. It was
Helpful. Regards, Wheelie from rhode island |
| All times are GMT -4. The time now is 06:16 AM. |
