-   -   Hydro won't move (https://www.onlycubcadets.net/forum/showthread.php?t=29507)
Giotundo 01-19-2014 03:35 PM
Hydro won't move
Hey fellas I just changed the filter and fluid in my new 125 and now I can move about a foot in reverse and nothing going foward. I changed everything because the gasket was slightly leaking and it'd never been change yet since I owned it. Any ideas what the problem is I'm very new to this.
R Bedell 01-19-2014 03:52 PM
What filter and fluid did you use..???
Muzzy 01-19-2014 03:59 PM
And how much fluid did you put in?
Giotundo 01-19-2014 04:12 PM
It's the correct trans filter and I put just shy of two gallons of hytran. I filled till it poured out the fill hole. Ran it for a while tried to move it foward and reverse then topped it off.
Muzzy 01-19-2014 04:18 PM
Is the lever for the pressure relief valves on?
R Bedell 01-19-2014 04:19 PM
Is the "input shaft" to the hydro unit rotating..???
Giotundo 01-19-2014 04:45 PM
The input shaft is spinning and the lever is in the drive position.
Muzzy 01-19-2014 05:10 PM
Did you clean out the rearend good When you drained it? It sounds like a plugged filter or the wrong filter.
Giotundo 01-19-2014 05:23 PM
I cleaned all the gunk out then sprayed with brake cleaner and wiped it all down. The filter is from ihccw and says it's for a cub 125 hydro. I'm 90% sure it's the correct filter unless I was sent the wrong one it says it right on it though.
Muzzy 01-19-2014 05:29 PM
It seems like you did everything right.
