-   -   Cub Cadet 1050 Plowing Snow (https://www.onlycubcadets.net/forum/showthread.php?t=29710)
jimbob200521 01-30-2014 08:24 PM
Well I did a little cleanup at work tonite and figured I'd share the video I took. It's a bit shakey and doesn't quite cover the 3rd gear plow at the like I'd like it too but enjoy what I was able to get, I'm trying to widen the path from the rear or the building to the front. Hope you enjoy!! :biggrin2: :beerchug:
http://www.youtube.com/watch?v=aqVGAiob-10
1811woody 01-30-2014 09:34 PM
Cool video Thanks for sharing. That looked like a pretty long drive thats gotta take some time when a major hits
ACecil 01-30-2014 10:12 PM
Great vid! Bet you had fun!
johncub7172 01-30-2014 10:33 PM
Nice hydro! I'd say with that set-up and the 54" blade, you got it under control! Good video!
J-Mech 01-30-2014 11:00 PM
Cool vid Ryan!
Need lights on your tractor, and your tranny makes a funny noise..... :bigthink:
Cubcrazy 01-31-2014 06:23 AM
Nice vid Ryan!:beerchug:
jimbob200521 01-31-2014 08:35 AM
Thanks guys!
The funny part is, that's not even part of the driveway I need to clean! What I posted a video of was me keeping "my" path clear. In other words, the shed is in the back of the building and all the sidewalks are up front so I have to keep a path clear around the building for me. Otherwise, when it snows, I'd have to drive on the roads around the block to get out front :biggrin2: And yeah, when we get a major snow, there have been times I couldn't make it through with the blade alone because that snow piles up so high. That's why I want, NEED, to get my blower back in action. I'm running out of places to put that stinking white stuff :bash2:
There's nothing hydro about that tractor; manual lift, and manual transmission :biggrin2:
Originally Posted by J-Mech (Post 240410)
Cool vid Ryan!
I do need nights on it but around the front and the back of the building is pretty well lit, just not through the side yard/walk :biggrin2: And as for the "noise" from the tranny, since this is the only gear Cub I've got to compare it to, I've never known any better. It got fresh Hy-Tran when I got it, no filter so couldn't change that, but it's always ran like a top for me, except when I had to have the gear shift fixed ;)
J-Mech 01-31-2014 09:56 AM
It's definitely making a noise it should not be. A whine, I think that's why John thought it was a hydro. Need to look into it. I suspect a bad bearing on the input. I hear it whenever you let out on the clutch, even in neutral, so it' either something rubbing the driveline, or an input/topshaft bearing in the trans. Better check it out before your down another tractor! :beerchug:
Sam Mac 01-31-2014 10:00 AM
Yep you have something making a bad noise in the drivetrain.
jimbob200521 01-31-2014 10:36 AM
Jeez John, you make it sound so bad; just because one KT17 blows up on me! :biggrin2:
And I was afraid of hearing something like that. Like I said, it's made that "whine" ever since I've had it. I've replaced pretty much everything (3 pin driver, drive flange, drive flange bushing, friction disc, pressure plate, drive spring, compression spring, spacer, release lever, bearing assembly, tranny fluid), except for the compression spring. Guess that means in the spring, I open her up even further. Doh! :bash2:
On the plus side, the 1811 is about ready for prime time so maybe she'll get a workout this weekend with the 5-6" we have coming :biggrin2:
