-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   169 exhaust question (https://www.onlycubcadets.net/forum/showthread.php?t=30195)
Shaner 02-22-2014 06:36 PM
I'm looking at my exhaust on my 169, with the K341 engine, and I noticed the elbow coming from the exhaust port to the muffler is different than normal ones, and mine is cracked and I touched it and a piece fell off of it....are these specific to the 169? or does the 1650 share the same one? I found one on cub cadet warehouse and it looked the same but not sure. any help would be appreciated.
R Bedell 02-22-2014 06:52 PM
You can go the the Cub Cadet Parts Look-up Site and it will answer all your questions. Click on.... Parts Look-up.
Click on Cub Cadet as the brand, and type in the model of your inquiry. It will bring up EVERYTHING that Cub Cadet ever made.
dvogtvpe 02-22-2014 07:19 PM
the 16 hp port is larger than all the other Kohlers, the QL ones are different so its exclusive to the 169
Shaner 02-22-2014 09:04 PM
I checked out that site Roland, both elbows on both tractors say KH-45-054-04 so with that being said I believe they are the same...right?
J-Mech 02-22-2014 11:51 PM
I tend to default to dvogtvpe on this one. But, you are correct...... They do show the same part number. :bigthink:
R Bedell 02-23-2014 06:50 AM
I don't have either a 169 nor a 1650, but I would agree with Don, that the 16HP elbows are bigger.
:Work:
Here is what my research has found. There are two exhaust elbows that look very similar. Here is the difference.
KH-47-054-01-S was used on engines from 10 to 14 HP
KH-45-054-04-S was solely used on K & M series engines for 16 HP
Mcamp 02-23-2014 09:58 AM
I replaced a 169 elbow with one from a 1650 for a guy, they were the same.
