-   -   Muffler advice on my #1250? (https://www.onlycubcadets.net/forum/showthread.php?t=31760)
nikster 05-04-2014 09:52 AM
The exhaust pipe needs to be extended by aprox. 4" on my # 1250 so that its belching beyond the the grill. (?)
What would be the EASIEST way to do this?
I'm sure there is a simple solution?
Buy some kind of pipe & clamp it on?
What would you do?
Thanks in advance for any easy, simple solution.
The exhaust is aprox. 1 1/4"
Nik,
http://i210.photobucket.com/albums/b...pslldtalrv.jpg
R Bedell 05-04-2014 10:33 AM
Yup, That is it.
Sam Mac 05-04-2014 11:49 AM
Nik
Other option may be to get that nice and round then see if you can find a pipe that will slip inside it then clamp or weld it. Looking at your pic I'm afraid it will be hard to get it to stay if it slips over the outside. If I was going over the outside then I'd weld it to the muffler, just my 2 cents.
finsruskw 05-04-2014 11:55 AM
Short piece of 1-1/4" thin wall electrical tubing is what I use on all my Q/L's
Do you have the screen with the oval hole in it?
I usually extend the pipe through the screen and miter the end then miter another short piece and weld to it to keep the exhaust off of the snow thrower in the winter as well as keeping the exhaust pointed away form the ground to avoid killing/scorching the grass during mowing season as well.
DarwinsFlinch 05-04-2014 12:09 PM
Originally Posted by Sam Mac (Post 259462)
Nik
Summit sells an expander tool for about 20 bucks if you want to go that far.
kostendorf 05-04-2014 02:05 PM
I would fix the tear in your pipe then a under the sink 90 deg. pipe fits perfectly. I hold mine on with a muffler clamp.
Attachment 51053
Cubcrazy 05-04-2014 04:40 PM
You could get another QL muffler Nik that has the extended outlet pipe.
nikster 05-04-2014 07:20 PM
Attachment 51053
B I N G O.
I like that look & price. Thanks all.
NIK
