-   -   1541 ignition switch wiring (https://www.onlycubcadets.net/forum/showthread.php?t=32110)
mferris72 05-21-2014 10:12 PM
I am working on a 1541 for a friend and the plug for the ignition switch is missing the plastic connector that holds all the wires. The spade clips are still on all wire so I can conect then individually to each terminal. My problem is that the switch ternimnals are not marked/labled. The top one in the picture is obviously the ground for the green wire because it is attached to the outer shell of the switch. I suspect I also have a bad solinoid, but need to resolve this issue before I can move on to that. These are the wires I have:
Black
Blue
Red/Black X2
Red/White X2
Yellow X2
Green X2
Does anyone have a diagram showing which terminal to hook thes 6 sets of wires to?
J-Mech 05-22-2014 12:49 AM
1641 is basically the same tractor. Check this thread out, you can PM Sam, he has a diagram. :beerchug:
R Bedell 05-22-2014 06:28 AM
Green = Ground
Yellow = Engine Kill
Red / White = Run & System Power
Red / Black = Start
Blue = Lights
Black = 12V from Battery
