-   -   Lift handle 102. (https://www.onlycubcadets.net/forum/showthread.php?t=32284)
retiredelectricguy 05-31-2014 10:20 PM
Lift handle 102.
My 102 lift handle spring is broke,how do I get it out to change? I took off the button,but there is a piece under it that I can't get out.Thanks
Sam Mac 06-01-2014 08:21 AM
Last time I did one I pulled the complete handle assembly out of the tractor to work on it. This is what your dealing with. Once you get the rod out of the center something with a hook should be able to get the spring out.
retiredelectricguy 06-01-2014 08:39 AM
Thanks,,Sam Mac,,
This may sound stupid,,but how hard is it to get the handle out? I have the mower on now,will it have to be removed? Thanks again. Joel
Sam Mac 06-01-2014 09:00 AM
Mower needs to come off. Here is the link to the service manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4641
Pretty much a PITA job. Maybe you can get something with a hook down inside and pull the spring out, worth a try.
retiredelectricguy 06-01-2014 10:01 AM
Spring.
I can't even see a spring.lol When I took the b utton off there seems to be another thing in the hole with short threads on it,,can't get it to come out.I'm sorry to keep bothering you and thanks much,,Joel
Sam Mac 06-01-2014 10:16 AM
The thing in the hole with the threads on it is the rod that runs all the way to the bottom, part #6 in the pic.
You may be able to push that rod down enough to get at the spring without removing the whole deal. Maybe some of the NF experts will chime in on this one.
retiredelectricguy 06-01-2014 11:17 AM
Thank you.
Thank you sir,I will try that and thanks again for your help an time...Joel
Cub Cadet 123 06-01-2014 12:09 PM
Whenever I had to remove the lift rod out of my old 107 that I used to have, I ran out of room to get it out of the bottom. I then drove it up on ramps to my trailer, parked it on an incline (and of course blocked the tires from rolling) and it came right out from the underside for me to work on. Good luck on your repair!
retiredelectricguy 06-01-2014 02:01 PM
Thanks.
I will try that,,Sure hate to take that deck off again,.,lol Thanks
sawdustdad 06-02-2014 09:44 AM
3 Attachment(s)
The button sometimes breaks in half where it necks down, leaving a piece of the button still screwed onto the top of the long rod that goes down the inside of the lift handle. If this is your situation, you'll need to drill and use a easy out to remove that part of the button . some pics might help...
