| jimbob200521 |
06-23-2014 03:32 PM |
Originally Posted by J-Mech
(Post 269255)
That's the price on the "cheap" blades Ryan. The hard coated ones are $35. As I've told you, I mow quite a large area. (For those who don't know: House I lived in last year, about 2 acres. Current house, 1.25-1.5 acres) I buy only CCC mower blades. I haven't replaced them for about 5 years. Suck it up. Buy the hard surface ones, and enjoy for the next several years. Or, buy cheap, replace every year, and spend the same or more. It's not even $100 man. (For the cheap ones.) Quit whining. :biggrin2:
Hey, it's my thread and I'll whine if I want to, whine if I want to, whine if I want to! You would whine too if it happened to you!! :biggrin2:
Seriously though, if that's what it takes, I'll have to start putting some money back. I just bought some more tools for the shop (finally got a decent impact gun!) so the blades won't happen right away.
Originally Posted by Mike McKown
(Post 269275)
I have one Cyclops here with a 1860, 46" mower. Original 1990(?) Cub Cadet blades on it. It's been mowing 1 1/2 acres every year for the last twenty years and there's still PLENTY of blade left. I sharpen them once a year.
The blades (Oregon) I put on my 1864, 54" deck last year ran all year and didn't get dull. I have yet to sharpen them this year as it still cuts good.
On the other hand, I have picked up decks that I know didn't have much time on them and the blades were completely eaten up and worn out. It has to do with how low to the ground your deck runs I guess.
Many years ago, I had a 108 w/42" deck I cut my 1 1/2 acres with. Blades wouldn't stay sharp and wore quickly so I bought the hardened tip blades. They stayed relatively sharp for a long time but were hard to sharpen.
Honestly, this is the first set of blades I've had to buy. Every machine I've had to far has had decent blades on it. I usually just sharpen and go. But this one, these aren't in decent shape. There's chunks missing from the back of at least one of the blades. I'm not getting good lift. My deck is level, I've checked the blade height as well as the deck shell height and I'm good to go there. The engine is also turning away at RPM like it should, so all that's left is the blades. :bigthink:
BTW, I checked out the Oregon blades you mentioned. Turns out, I've got a couple Oregon Blade dealers within 3 miles of my house so I may give those a shot. :beerchug:
