-   -   50" deck rebuild (https://www.onlycubcadets.net/forum/showthread.php?t=32829)
cfiles 06-25-2014 02:58 PM
50" deck rebuild
3 Attachment(s)
So I picked up a 1872 some time ago and i'm finally getting around to rebuilding the deck on it. I like looking at others pictures, so here are some of my progress.
[ATTACH][ATTACH]Attachment 53256[/ATTACH][/ATTACH] Messed up some threads on all three spindle shafts.
cfiles 06-25-2014 03:05 PM
4 Attachment(s)
Then i got parts back from sand blaster, and cleaned up the rest.
Attachment 53257
Attachment 53258
Attachment 53259
Attachment 53260
cfiles 06-25-2014 03:13 PM
I plan on replacing bearings, seals and top nuts on spindles. I wound up with two good spindle shafts. And I have one of the " pump bearings" that is good off of another 50" deck. Is there a reason I couldn't use the pump bearing on one spindle (middle) and the shafts on the other two? Also, is the seals the same part # on the pump bearing?
ACecil 06-25-2014 03:15 PM
Good work! Looking forward to your updates.
Cubcrazy 06-26-2014 06:16 AM
X2!:beerchug:
cubcadet 06-26-2014 07:14 AM
Nice work, also looking forward to updates.:beer2:
sbauerz28 06-26-2014 08:03 AM
Nice job on the deck. It looks better than mine did. The more I hit mine with the wire wheel the more pin holes I found. Atleast my bearings and spindles were all good so that one less thing to fix.
cfiles 06-29-2014 08:35 PM
4 Attachment(s)
Got a lot of parts painted, wet sanded and repainted. Waiting on bearings and seals. Still need to order couple pulleys. Some progress pics. [ATTACH]Attachment 53423[/ATTACH][ATTACH]Attachment 53421[/ATTACH]
darkminion_17 06-29-2014 08:54 PM
looks good,I have few you can do here.
How much did the blasting run yah?
ACecil 06-29-2014 10:04 PM
Looking real good!
