| most-basic |
07-17-2014 02:45 PM |
149 odd engine oil leak!!
i have a 1972 149 that runs like a champ. its up at our cabin where i do work on peoples yard with it.. i go up every weekend. i went home on Sunday then cam back on Friday 2 weeks ago and when i came back i found a dead batter cause someone (me) left the key on so i charged her up and then i noticed that by the under the coil on the frame there was a wet spot that look to have dust and grass clippings etc on it so i though o on just some gas from the gas valve from the last time i ran it. so then i was cutting a yard the next day and it got worse so i stopped to look at it and i saw oil dripping down the coil and the top of the coil was wet. also i have the battery charged to all that i could get it to take which is i believe was 95% but when i run the engine at wot the charge meter goes goes way up and then i idle it down it goes to normal and at about quarter throttle the meter goes to up half way to the charging side... is that a problem?
