-   -   Now my 149 won't start (https://www.onlycubcadets.net/forum/showthread.php?t=33529)
Steve149 07-25-2014 04:14 PM
I was going to back it out of the shed to take the deck off for some repairs and when i tried to start it nothing...all i hear is a loud clicking under the dash. I mowed last night and it worked just fine???? I dont get it
Alvy 07-25-2014 04:54 PM
Sounds like solenoid may have went. You need to test positive in and out of solenoid with a test light or meter. 12v in on big lug from battery, 12 volts out on other big lug on other side of solenoid going to s/g in key switch crank position
Steve149 07-25-2014 05:13 PM
Yepper thats what it is...if I dont have bad luck i have none at all
bocephus1991 07-25-2014 05:13 PM
Check your battery connections be sure they are clean and tight and that the battery is good.
yeeter 07-25-2014 08:41 PM
I have had this on a number of occasions. Wiggle them or clean them, make sure the ground is good. With luck its just this....
red56turbo 07-25-2014 09:21 PM
Check your battery connections be sure they are clean and tight and that he battery is good.
I agree. A low battery or loose/dirty connections can cause these symptoms. I'd check the simple stuff before moving on to replacing the solenoid. In the end, still might be a bad solenoid.
Cub Cadet 123 07-25-2014 11:48 PM
I just had this exact same problem on one of my 129's and it was the solenoid, but doesn't hurt to do a check of all connections anyway.
bocephus1991 07-26-2014 01:10 AM
I have found most times it's something simple. Loose wire , dirty cables forgot to turn the fuel on! Lol safety switch on clutch pedal not making good contact. I have had that happen too. Accidently flipped the pto switch on left the key on and burned points up.
Steve149 07-26-2014 11:09 AM
Well I bypassed the solenoid and the S/G started to turn over just fine...I have to replace it today at some point.
Alvy 07-26-2014 12:07 PM
Glad you got it
