Engine test stands?
Hi guys, I was wondering if anyone has built a stand for testing motors before dropping them into the tractor. I have a couple engines kicking around, and i was thinking it would be nice to mount them onto something to find out what works/doesn't without having to dismantle a working tractor. anyone done this? how did you go about it?
Seems to me all you'd really need is something to secure it to (metal plate, 2x12, anything will work), a source of fuel (I'd suspend a small tank above the motor), a 12v battery and something to crank the motor (screwdriver, extra swtich, etc.).
Would be a pretty cool idea if you would use it enough :beerchug: |
My motors always run when I put them in. :biggrin2:
if you have a junk parts tractor sitting around just cut off the front of the frame and weld some legs to it.
4 Attachment(s)
I bolt them to the motor plate then clamp the plate to my work bench, hook a temp fuel and electric system and fire them up. The diesels are a little more complicated to deal with but I also do them.
I seen one on another forum years back. It was custom built and Neat.
| All times are GMT -4. The time now is 01:30 PM. |
