682 Blades spin while tractor turns over
Went to start the 682 and the blades spin while trying to start it. The fuses are good, pto belt tension good, I replaced the pto switch, bypassed seat saftey switch. Still does it. Any help would be appreciated
If you mean the PTO is engaged when you start then you probably have a seized PTO bearing. It is fairly common and happened to me a few years ago.
did you take the belt off the PTO? I assume it starts fine if you do. here are some threads to review: http://www.onlycubcadets.net/forum/s...ad.php?t=10653 http://www.onlycubcadets.net/forum/s...ad.php?t=33516 Goodluck- |
I'd look into the bearing, as well. I had the same thing happen; started fine one day, the next the deck starts with it. Replace or repair the bearing and see what happens. Good luck :beerchug:
Take the belt off the PTO and try to spin the pulley....it should spin rather freely. Then, like suggested above, the bearing could have seized up.
tim |
Thanks everyone, you were spot on. The bearing was hosed, mower is fixed.
| All times are GMT -4. The time now is 04:04 AM. |
