Clutch Rebuild-Manual Transmission
I purchase a 100 with a 42 inch mower deck and front blade at an auction in the fall of 2012.
http://i152.photobucket.com/albums/s...0100/rd003.jpg http://i152.photobucket.com/albums/s...0100/rd001.jpg http://i152.photobucket.com/albums/s...0100/rd002.jpg http://i152.photobucket.com/albums/s...0100/rd004.jpg This 100 is one of the quickest starting garden tractors I've own. When you tried to engage the mower it acted like something was in a bind and not letting the mower blades spin. The problem ended up being the pulley was against the mule drive. The welded nut inside the frame was missing and the mule drive was bent. Only way to fix it was to remove the engine. The clutch between the engine and trans was acting up too (someone installed a wide frame clutch). While I need to remove the engine to weld the nut back on I will fix the clutch too. Removing the clutch is easy to do if you follow your repair instructions in your Cub Cadet manual. I had an extra narrow frame clutch to use. Narrow Frame Clutch Assembly: http://i152.photobucket.com/albums/s...ps7f662eb6.jpg I wanted to take clutch assembly apart to make sure everything was ok. Here are the special tools I use to disassemble/assemble a clutch assembly: http://i152.photobucket.com/albums/s...ps8bdad51f.jpg First thing I notice the throw out bearing was froze up. One of the first things I do is to remove coupler joint between the trans and driveshaft. I use my V-block to hold the clutch and hang the clutch disk over the edge: http://i152.photobucket.com/albums/s...ps7f508df3.jpg I use a spiroid pin punch to drive the pin out. http://i152.photobucket.com/albums/s...ps957c4c7b.jpg Notice the pin is over the edge so it has a place for the pin to go. |
Notice the location of the pin in relation to the V-block:
http://i152.photobucket.com/albums/s...ps90c39577.jpg Next to removed is the pin holding the spring in place: http://i152.photobucket.com/albums/s...ps0e4edec2.jpg The bolt in the picture is an important safety feature that is a must if you use a jig like this one: http://i152.photobucket.com/albums/s...ps9ebdf31c.jpg Pin out: http://i152.photobucket.com/albums/s...ps5c73097f.jpg Here are some of the tools I use and the spring: http://i152.photobucket.com/albums/s...psd13313f5.jpg The next I like to do is remove the pin(s) that hold the pressure plates on the driveshaft. I will turn the clutch assembly end for end to use my jig to remove the pins. http://i152.photobucket.com/albums/s...ps24598f1a.jpg Closer view: http://i152.photobucket.com/albums/s...ps135c702d.jpg Front pin being removed: http://i152.photobucket.com/albums/s...ps09662b59.jpg |
Clutch assembly is apart. Here is what the clutch disc looks like:
http://i152.photobucket.com/albums/s...ps2eeeb57f.jpg The pile to the right of the clutch disc is part of the clutch disc. Pressure plates: http://i152.photobucket.com/albums/s...psda0b6ab2.jpg Release arm: http://i152.photobucket.com/albums/s...psc94b8e26.jpg You need to look for excessive wear where my finger is pointing to: http://i152.photobucket.com/albums/s...ps0d968f6b.jpg This release arm is in good shape. The area where my finger is pointing to is where the throw out bearing goes. http://i152.photobucket.com/albums/s...psfc1a614c.jpg The driveshaft needs replace. Tomorrow we will make a list of parts that need replace. |
Picture of area in question: http://i152.photobucket.com/albums/s...psd6e85463.jpg http://i152.photobucket.com/albums/s...ps115162a9.jpg |
One of the main reasons for this thread is to show how easy it can be to rebuild a clutch. |
I'm not a big fan of using a press. The tool I use can go to an event and is much easier to use than a press. |
The last item I check out is the 3 pin driver.
http://i152.photobucket.com/albums/s...psdaa68f30.jpg The picture shows the wear on the pins. Worn pin(s) will make the holes in the clutch disc go oversize and the pins could shear off. It will make the clutch go out of balance and the tractor will have the shakes. I will replace the bushing in the 3 pin driver too. |
Parts that are needed to rebuild the clutch assembly
bushing-3 pin driver 3/8 X 1 1/2 steel coiled springs pin (need 3) clutch disc true pressure plates teaser spring throw Out bearing drive shaft 5/16 X 1 1/4 steel coiled springs pin (need 3) 5/8 diameter clamp on shaft collar-I do not like to use a steel coiled spring pin in any drive shaft I rebuild. It leaves a weak point in the drive shaft. Time to do some shopping |
I have a list to compare prices.
Bushing-3 pin driver Cub Cadet-$5.58 McMaster-Carr-$3.22 Cub Cadet Classics-$5.50 Garden Tractor Pulling Tips-$3.00 Teaser Spring Cub Cadet-$4.33 Midwest Super Cub-$5.18 Cub Cadet Classics-$3.75 Garden Tractor Pulling Tips-$5.00 Throwout Bearing Cub Cadet-$55.58 Midwest Super Cub-$55.00 Zach Kerber Machine & Design-$25.50-See note A Patton Acres-$28.70 Clutch Disc Cub Cadet-$48.97 Cub Cadet Classics-$45.00 Midwest Super Cub-$37.85-See note B Patton Acres-$29.00 Garden Tractor Pulling Tips-$40.00 Narrow Frame Clutch Pedal Return Spring Cub Cadet Classics-$5.50 Patton Acres-$8.00-See note C Garden Tractor Pulling Tips-$5.00 Cub Cadet-$6.31 Drive Shaft Patton Acres-$48.20 Midwest Super Cub-$30.00-See note D Zach Kerber Machine & Design-$25.00-See note E Garden Tractor Pulling Tips-See note F Split Collar Garden Tractor Pulling Tips-$3.00 McMaster-Carr-$5.15 Clutch Pressure Spring Cub Cadet Classics-$26.00-See Note G Cub Cadet-$25.56-See Note H Clutch Pedal Return Spring Cub Cadet-$6.31 Note A-Bearing has a longer sleeve. Will need to use a 2 piece collar Note B-Kevlar/Fiberglass material Note C-Used spring Note D-4140 Material-No hole behind spring Note E-4140 Material-No holes behind spring and coupler Note F-1144 Material -$45.00 304 Stainless Steel-$30.00 Note G-Blue Spring-550-600 pound pressure Note H-Stock Spring-250-300 pound pressure Time to order parts The prices above are 2014 prices. |
Parts I ordered are:
McMaster- bushing-3 pin driver 3/8 X 1 1/2 steel coiled springs pin (need 3) 1/4 X 1 1/2 steel coiled springs pin (need 3) 5/8 diameter clamp on shaft collar H.G. Violet-(local Cub Cadet dealer) teaser spring throw Out bearing Narrow Frame Clutch Pedal Return Spring Midwest Super cub clutch disc drive shaft I true pressure plates on My Father's lathe. Parts from Midwest Super Cub and McMaster were ordered today. The parts from H.G. Violet will ordered Monday morning. |
