Wide frame puller
I found a 782 wide frame. I am building a modified puller. I have a 104 parts tractor. Will the narrow frame rear bolt in the wide frame? I can't seem to find a clutch pedal. Will a quiet line pedal work? I will be building a new clutch. Thanks for the help
Rear end is the same I would think clutch pedal will work also
What's wrong with the pedal on the 782? It is the same pedal for the hydro trans and the gear drive.... You just need the linkage and the hangers. No, the clutch parts won't interchange from the QL to the '82 series.
thanks alot.
| All times are GMT -4. The time now is 10:39 AM. |
