Lift ratchet, spacer assembly
Looking for dimensions of the Lift ratchet, spacer assembly (part 9) for a 127.
I'm converting it over from electric lift to manual and have all the other parts. In reality I only need the depth of the spacer from the frame to the tooth bar |
Well..... I don't have one that's easy to get to to measure....
But, the bolts are listed as 2 1/4" long, and I know that they have a lock washer on them. The "rooster comb" is about 1/8" thick, and so is the frame, the washer and nut will take 3/8" or so... and 1 5/8" would be close. I guess you can try that and shorten as necessary. Or just put it all in the frame and take a measurement if no one else chimes in. Could also check with the sponsors above and see if any of them have the part in question. :beerchug: |
Between 1 1/2 and 1 5/8 so 1 9/16th? I could mic it if you want or come by and I could give you 1. I have many
Thanks all.
Close enough to get me started. I have the assembly in the tractor as of last night, I'll start long at 1 5/8 and adjust from there. mmzullo, I'd love to stop by but 2hrs and 15min would be a small miracle with a 18 month old and a 3yr old. :Boohoo: |
| All times are GMT -4. The time now is 06:41 AM. |
