-   -   Dozer Blade assembly question (https://www.onlycubcadets.net/forum/showthread.php?t=34719)
Steve149 09-18-2014 09:04 AM
Does anyone know how tight the castle nut has to be that holds the pivot frame to the main frame of the plow?
This is what I started with...a mess to say the least but I used the electrolysis technique to remove the rust/paint and things are looking good. I will put up pics of the finished product as soon as i get it assembled.
drglinski 09-18-2014 09:25 AM
I got mine tight enough that it would just pivot...then I used it winter 2013/14 then had to tighten it again. It's a feel thing for me.
olds45512 09-18-2014 09:36 AM
I also go by feel, you want the nut to be as tight as you can get it while still being able to turn the blade.
Steve149 09-18-2014 11:05 AM
sounds good guys thanks much!!!
Steve149 09-18-2014 11:11 AM
the only other thing that i need for this is the IH decal and I haven't been able to find any that size.
kostendorf 09-18-2014 11:29 AM
This is where I found the decals for my blade and #2 cart.
http://www.binderbooks.com/ih_individual_decal.html
http://www.superscoutspecialists.com...ih-decals.aspx
Steve149 09-18-2014 11:46 AM
Originally Posted by kostendorf (Post 287263)
cool thanks I will check them out...
Steve149 09-18-2014 02:04 PM
They are exactly what I need...I appreciate the heads up:beerchug:
drglinski 09-18-2014 03:32 PM
I got mine from these guys last summer
http://www.aldermans.com/
called them up, told them what I needed, and they mailed me one.
Steve149 09-22-2014 10:08 AM
I have another issue the washer that is supposed to go under that Castle nut on the pivot plate was shot and I picked one up at the hardware store in Stainless only to find that it is too think to allow me to get the cotter in place. I have checked the local hardware stores and can't find one thinner any suggestions?
