-   -   Anyone load there tires with sand? (https://www.onlycubcadets.net/forum/showthread.php?t=34891)
bocephus1991 09-29-2014 12:47 AM
Has anyone here ever loaded their tires with sand? Good idea , bad idea? I was thinking of loading mine with sand. My tractor stays inside out if cold and moisture. I can also see the sand attracting what moisture there is in the air causing rust . Looking for opinions . Thanks!
cubby102 09-29-2014 01:33 AM
I think it'd be more hassle then its worth. Other then attracting the moisture and holding it its going to pull the paint off the wheel causing it to rust even quicker as well as its going to slowly sand down the inside of the tire....go get ya some cheap winter windshield washer fluid. If ya wanna keep it down road. And just a thought rimguard at least in my are isnt only about 55 bucks for enough to fill 10.50s
DoubleO7 09-29-2014 09:17 AM
Washed and dried pool filter sand ?
Once in the tire, where is it going to absorb more moisture?
If you had the inside surface of the rim Linex'ed, the sand would not rub the paint off the rim at all.
Even coating the rim with tar might do the same job.
With that said, it might be a pain to keep the Schrader valve from sealing due to grains of sand interfering with the seal.
You would definitely want the valve at 12 noon when checking psi, etc.
cubby102 09-29-2014 02:27 PM
By the time u did all that prep to the rim to try and slow the processes down which I think it would eventualy strip it anyway. You'd be in the same ballpark price of windshield washer fluid. And would last much longer
CADplans 09-29-2014 02:54 PM
I would rather have an aluminum clutch!!
http://www.onlycubcadets.net/forum/s...ad.php?t=34870
:bigthink:
:biggrin2:
Yosemite Sam 09-29-2014 02:56 PM
I suggest that when you try to inflate the tire, some (perhaps quit a bit) of the sand would want to escape from between the tire and the wheel.
Once the bead does seal, I believe some of the sand would be trapped between the wheel and the bead of the tire, this could potentially cause the bead to leak and over time, the trapped sand could eat away the edge of the tire and the wheel as well, only causing the leaks to become worse.
I do think someone should try this and report back to us, maybe a couple of times a year, in ten years or so we will have a definite answer.
darkminion_17 09-29-2014 03:56 PM
This was discussed before
http://www.onlycubcadets.net/forum/s...ght=sand+tires
DoubleO7 09-29-2014 04:10 PM
Use powdered lead!
Sam Mac 09-29-2014 06:20 PM
RV anti freeze, windshield washer fluid or Rim Guard. End of conversation. :beerchug:
jimbob200521 09-29-2014 06:27 PM
:IH Trusted Hand:
