-   -   Kohler K321 Flywheel Pulley With Clutch (https://www.onlycubcadets.net/forum/showthread.php?t=35243)
NE149 10-16-2014 07:54 PM
Kohler K321 Starter Pulley
Need the flywheel pulley with clutch for a Kohler K321... for a 149. Message me here or reply please. I'm in Nebraska. Doesn't have to be new but the set screws must come with it.
Note: This thread was moved because it ended up being instructional. No parts needed now.
~J-Mech
J-Mech 10-16-2014 08:03 PM
You need a PTO clutch? Or are you talking about the basket pulley? Because the flywheel doesn't have a pulley with a clutch on a 149.... :bigthink:
NE149 10-16-2014 08:24 PM
I'm using terminology that I read lol... this thing
http://ccspecialties.org/pics/kh231591pulley.jpg
J-Mech 10-16-2014 08:36 PM
Basket pulley. Or, starter/gen pulley.
The flywheel is on the other end of the motor. :beerchug:
NE149 10-16-2014 08:49 PM
Yep I knew that! I've almost got it all re-assembled but the carb and the front end pulleys and such... just trying to avoid buying a new pulley but I'm thinking that is what I'll have to do.
J-Mech 10-16-2014 08:52 PM
What's wrong with yours?
NE149 10-16-2014 08:53 PM
One of the set screws on the one I got off a collector was screwed in cockeye'd and couldn't be threaded back in...
J-Mech 10-16-2014 09:01 PM
So..... run a tap through it.
Or, drill and tap a new hole. No need to replace.
NE149 10-16-2014 09:01 PM
What size is the hole? 1/4" Tap is too small, 5/16 seems too big?
J-Mech 10-16-2014 09:06 PM
5/16" x 18
