-   Home Made (https://www.onlycubcadets.net/forum/forumdisplay.php?f=48)
-   -   Rear weight bracket/cargo rack (https://www.onlycubcadets.net/forum/showthread.php?t=35384)
zling 10-24-2014 09:48 PM
6 Attachment(s)
had this weight bracket I made a while back to hold 2 cement blocks for help with plowing snow. This summer I got a FEL 128 so it ended up on it and I've been messing around in the woods with it clearing trails and cutting firewood so i decided i needed somewhere to carry my saw, fuel can, oil, tools, ax etc. So heres what i came up with just painted her up will get it all mounted up tomorrow. let me know what you think
bocephus1991 10-24-2014 10:43 PM
Looks like it should work! That second to last pic it looks like a BBQ grill! Put done burgers on and grill supper while you mow or move dirt!
zling 10-25-2014 12:19 PM
3 Attachment(s)
finished pics or at least finished for now
Sam Mac 10-25-2014 05:33 PM
Looks like a well thought out solution to me. :beerchug:
zling 10-25-2014 06:29 PM
2 Attachment(s)
Thanks it go a lot of use today works great for firewood duty pulls logs really well but for that work I prefer my 148
IHCadetCollector 12-22-2014 08:08 PM
Good idea but, too much weight abd every time you hit a bump you'll be popping wheelies!
zling 12-28-2014 09:46 PM
too much weight? no such thing especially with a loader on the front.
J-Mech 12-28-2014 09:58 PM
That's what you think..... till the thing between the loader and the rear bracket decides it wasn't made for that kind of weight. :bigeyes:
zling 12-28-2014 11:03 PM
I beef up everything on my tractors they are far from stock underneath. I like pushing the limits of these old cubs
J-Mech 12-29-2014 12:26 AM
On the frame? Or did you install larger bearings in the rear axle tubes, maybe larger diameter axles.....
In your pics I don't see 5, or even 4 bolt wheel hubs on front, so your still running on a 3/4" axle shaft. Even if you upgraded to a 1" one, it's still too small for all the weight of a loader with a load on it. How about the front pivot rod on the axle? Is it larger?
As far as I'm concerned, a FEL on a stock GT is just an accident waiting to happen. Just not big enough for that kind of load. SGT.... they are a little better to put one one. If nothing else, longer WB makes a huge difference. I just hope you don't find the weak point when you have 7-800# hanging on the front. It is a tractor, but not a big tractor.
