-   -   "A" stamp on a k241? (https://www.onlycubcadets.net/forum/showthread.php?t=35845)
CubOCD 11-23-2014 07:43 AM
Hey guys,
I have a cub 108 with a k241A 10hp in it. I am new to this but I removed the head and the block and piston was stamped with an "A" on it. Does this mean that the engine has never been rebuilt? It seems to have decent power but the piston does have a little play in it. I am still learning all this stuff :bigthink:
Thanks!
sawdustdad 11-23-2014 09:13 AM
Somebody with more engine experience (J-Mech perhaps) will come along shortly and confirm, but I think that's correct. Any replacement piston will be stamped .010, .020 or.030. My 108 with the K241A had an "A" on the original piston.
J-Mech 11-23-2014 09:57 AM
You are correct Frank! :beerchug:
Well...... it's not supposed to be tight.
Do you feel a "ridge" at the top of the cylinder?
CubOCD 11-23-2014 11:39 AM
I don't believe it had a ridge. I guess I was assuming that by now it would need one and that it should be tight. Thanks for the info :)
binderfever 11-23-2014 12:07 PM
If you don't feel a ridge, the bore looks in decent shape, it's not using oil or knocking you are probably fine.
J-Mech 11-23-2014 01:29 PM
Not probably. It's fine.
bocephus1991 11-23-2014 05:08 PM
When I rebuilt my k301 I didn't find much of a ridge at the top of the cylinder, but found one at the bottom of the cylinder.
