More folks who shouldn't own tools
Jonathan will really get a kick outta this-I sold an engine kit to this guy building a 389 Pontiac V8 in a GTO for one of my customers. Today he brings back one pair of main bearings, saying they don't fit, but all the others did fit fine. He told me it is a 1966 when it is actually a 1964, and figgered the wrong year model was the reason. I knew the catalogging showed all the same mains/rods etc. for 59-66.
They were the wider thrust main bearings that keep the crank from walking.:bigthink: And this guy is building an engine. Same guy built a "standard bore/std crank 1965 327" a few months back, I was incredulous he had found a standard bore Chevy 327. Most of those didn't survive the '70s... He brought everything back. Was actually a 57 283, bored .060 over .030/.030 on the crank, so I re-ordered and sent stuff back... One month later, he wanted it all again, and rebuilt it yet again. |
Some people make my head hurt. :bash2:
If that guy was like most people around here, you can't tell him a gal-darn thing either. Knows it all. :BlahBlah: |
education isnt cheap .... wonder whos payin his bill
My customer(who is also a neighbor) is paying the bill-I'm kinda in a catch-22-I make money sellin' parts but......
Sold 5 std rod brgs annd one .010 under rod bearing for an 806 IH this week also...:bigthink:
Same way here. Know-it-all's
I love the folks who pull off the battery cable on new stuff to see if the alternator is charging. Sold a handful of ECM's that way.... I just use a cheap voltmeter. |
We have a customer who just bought a ford tractor that had been sitting for some time, one cylinder was full of water and all rusty and he wants to know if he can just replace that liner and piston and not worry about the other 3.we advised him against it but he did it anyway, turns out the other 3 cylinders are very low on compression and the block is cracked, the bad part is he bought it with the guys word it just needed points and he paid about $2000 more than its worth.:bigeyes:
Buyer beware-The guy with the 806 rod bearings said it only had to drive onto the trailer.....he did buy 6 feet of emery cloth..
I swapped a free VW dune buggy years ago for a 76 Chevy C10, 350/automatic. It was a mosquito fogger, so I pulled it apart after attempting to blow it up. Had small valve head on one side, large on the other, all the ring gaps were lined up perfectly, two pistons had no skirts at all and they weren't in the pan.:bigthink: |
Some folks shouldn't own equipment either. There's a guy my dad knows that bought a brand new Kubota about 10yrs ago, after having it for only a month he was doing some yard work with it and needed to pull out a small tree stump. Not wanting to scratch his new tractor with the chain he preceded to put the chain around his waist and got on the tractor and started driving away, as you can imagine when the chain got tight it ripped him off the tractor and broke most of his ribs. To add insult to injury the tractor( now unmanned ) preceded across the yard and down over a very steep embankment flipping end for end.
| All times are GMT -4. The time now is 12:20 AM. |
